Author Topic: Skag Charging Issue  (Read 1480 times)
TxLandman
Skag Charging Issue
« on: April 16, 2014, 10:47:10 PM »
I saw your video regarding a Skag having charging issues to the battery, I as well traced it back to the 20amp fuse. Did you ever determine what was causing the fuse to blow?
Thanks,
Jeff
Re: Skag Charging Issue
« Reply #1 on: April 17, 2014, 03:56:57 PM »
No. I checked the entire wiring harness, connections, everything I thought might cause the problem. I didn't find anything wrong, and the problem never happened again.
TxLandman
« Reply #2 on: April 18, 2014, 07:23:26 PM »
Well hopefully I won't have anymore issues out of it, I never have before so this was odd! Thanks for your reply, have a good weekend!
Thanks again,
Jeff
Texas
