Author Topic: pain in the butt push mower  (Read 1538 times)
mowerman14
« on: February 01, 2014, 01:18:43 AM »
Ok, here's the deal. I'm really experienced in small engine repair, but this one has me for a spin. I have a 700 series Briggs. I replaced: flywheel, crank shaft, connecting rod, and keyway. I go to start it after I do all of this and all it does is blow fule mist out the intake towards the air filter.  Now, usually this implies a shredded keyway or bad timing, but both are perfact. It gives a kick off starting fluid and governer seems fine, so what the heck is the problem?!
Re: pain in the butt push mower
« Reply #1 on: February 04, 2014, 10:12:10 PM »
How do you know the ignition and mechanical (crank/camshaft) timing is correct?
What do you mean when you said "It gives a kick off starting fluid?"
