Author Topic: 2012 Police Electraglide Classic FLHTP  (Read 1638 times)
greggeo
« on: January 15, 2014, 02:44:39 PM »
When Doing a brake Pad Change on a Harley with ABS is it Necessary to be concerned about the Computer Sensors with ABS That Requires a Dealer to Do the Work so They can Link Up with a Program to Get Everything Dialed In?
Thank You,
Greg
Re: 2012 Police Electraglide Classic FLHTP
« Reply #1 on: January 28, 2014, 11:29:44 PM »
I don't think you need to worry about the ABS module, but check the bikes manual. The only time you would need to access the ABS module through the bikes computer is when you get air in the ABS module and you need to bleed the module.
