Author Topic: Briggs vanguard OHV (runs for 15 min then dies)  (Read 1639 times)
kodibass
« on: October 10, 2013, 04:22:49 AM »
I have a briggs 15 hp vanguard it runs for about 15-20 min then dies & wont restart until it cools back down  what would most likely be the cause?   thanks
Re: Briggs vanguard OHV (runs for 15 min then dies)
« Reply #1 on: October 10, 2013, 03:35:18 PM »
What is the model number of your engine?
After your engine warms up and it stops running, have you tried checking the engine for spark?
When you remove the spark plug(s) to check for spark is the end of the plug wet?
mowerman14
« Reply #2 on: February 01, 2014, 01:30:18 AM »
 those are old engines and can get worn out. In some cases you need to replace rings and/or piston. Also, might want to check seals. Like the head gasket.
