Author Topic: Predator 212cc Custom valve cover with breather hose  (Read 1697 times)
userix
« on: December 14, 2015, 02:11:32 AM »
I have a custom short CNC valve cover for my predator 212 cc motorized bike.  The CNC head I have doesn't have any breather hose.  It's a completely sealed valve cover, which I know is bad because there is no way the excess crankcase pressure can escape.  I modified the valve cover by adding a barb hose connector and attaching a breather hose connected to a makeshift oil catch can.
It is necessary to also put a one-way check valve on the breather hose?  I'm not sure if having the crankcase open to the outside atmosphere without a one-way check valve is bad.
Re: Predator 212cc Custom valve cover with breather hose
« Reply #1 on: December 18, 2015, 06:54:07 PM »
You want the crankcase to maintain a slight vacuum or be less than atmospheric pressure. That is why the stock valve cover has the check valve.
