American V-Twin Motorcycles.
Photo's Of Harley Davidson Pan America Revolution Max Engine
Topic: Photo's Of Harley Davidson Pan America Revolution Max Engine (Read 441 times)
February 26, 2021, 07:29:39 PM »
What I know about the Harley Davidson Pan America Revolution Max engine:
Displacement is 1252cc
150 HP, 94 llbs-ft torque.
48 mpg
Liquid cooled, 60 degree V-Twin, DOHC, VVT (variable valve timing)
Oversquare: bore to stroke ratio 1.46
6 speed manual transmission
Oil system uses 3 scavenge pumps.
Uses friction reducing low tension piston rings
Hydraulic valve adjusters
Compression ratio is 13.0:1
Transmission shafts are vertically stacked for a high output sprocket position and short engine size.
Slipper/assist clutch uses 8 friction discs
Clutch, Alternator and Cam covers are made from Magnesium for lighter weight
Click on any image to enlarge it:
I don't think this is the same Revolution Max engine used on the Pan America, but very similar if not the exact same design
Last Edit: February 27, 2021, 05:44:32 PM by adminjoe
