Author Topic: 2021 Harley Davidson Pan America Specifications And Pricing Released Today  (Read 458 times)
The 2021 Harley Davidson Pan America Adventure motorcycle specifications and pricing were release today and the bike will be available for sale at  Harley Davidson dealerships in USA on May, 2021.
Curb weight is 534 lbs and engine horsepower is a whopping 150. Torque is 94 ft-lb.  The base price is a $17,319. See video and specs below. Visit the Harley Davidson Pan America website here: Harley Davidson Pan America
<a href="https://www.youtube.com/v/WF3pBM4eViE" target="_blank" class="new_win">https://www.youtube.com/v/WF3pBM4eViE</a>
Base model specifications:
Dimensions
Length - 89.2 in.
Seat Height - 31.8 in.
Ground Clearance - 8.3 in.
Rake - 25
Trail - 6.2 in.
Wheelbase - 62.2 in.
Tires, Front Specification - 120/70R19 60V
Tires, Rear Specification - 170/60R17 72V
Tire, Type - Michelin®Scorcher®“Adventure”, Radial
Fuel Capacity - 5.6 gal.
Oil Capacity (w/filter) - 4.75 qt.
Weight, As Shipped - 503 ln
Weight, In Running Order - 534 lb.
Engine
Engine - Revolution® Max 1250
Bore - 4.13 in.
Stroke - 2.84 in.
Displacement - 76.3 cu in
Compression Ratio - 13.0:1
Fuel System - Electronic Sequential Port Fuel Injection (ESPFI)
Exhaust - 2-into-1-into-1; catalyst in header
Performance
Engine Torque Testing Method - J1349
Engine Torque - 94 ft-lb
Engine Torque (rpm) - 6750
Horsepower - 150 HP / 112 kW @ 9000 rpm
Lean Angle, Right (deg.) - 42
Lean Angle, Left (deg.) - 42
Fuel Economy Testing Method - Estimated City/Hwy
Fuel Economy 5 - 46 mpg
Drive Train
Primary Drive - Gear, 49/89 ratio
Gear Ratios (overall) 1st - 13.11
Gear Ratios (overall) 2nd - 9.687
Gear Ratios (overall) 3rd - 7.509
Gear Ratios (overall) 4th - 6.057
Gear Ratios (overall) 5th - 5.08
Gear Ratios (overall) 6th - 4.436
Chassis
Front Fork - 47mm inverted fork with compression, rebound and spring preload adjustability. Aluminum fork triple clamps.
Rear Shocks - Linkage-mounted, piggyback monoshock with compression, rebound and hydraulic spring preload adjustability
Wheels, Front Type 9 - Aluminum cast, satin black
Wheels, Rear Type 9 - Aluminum cast, satin black
Brakes, Caliper Type - Front: radially mounted, monoblock, 4-piston caliper; Rear: floating, single piston caliper
Electric
Lights (as per country regulation), Indicator Lamps 8 - LED Bullet Turn Signals
Gauges - 6.8 inch viewable area TFT display with speedometer, gear, odometer, fuel level, clock, trip, low temp alert, side stand down alert, TIP over alert, cruise, range and tachometer indication BT capable - phone pairing to access phone calls, music, navigation (H-D   App ONLY)
Infotainment
Type - Color TFT w/ Touch
Screen Size - 6.8 in.
Headset Specifications (if equipped) - Bluetooth
Languages - Arabic, Chinese (Simplified/Traditional), Czech, Danish, Dutch, English (default), Finnish, French (Canada/France), German, Greek, Hungarian, Italian, Japanese, Korean, Norwegian, Polish, Portuguese (Portugal/Brazil), Indonesian, Russian, Slovak, Spanish (Mexico/Spain), Swedish, Turkish, Vietnamese, Thai
Hands-free Mobile Phone - via Bluetooth - Yes
Voice Recognition Languages: Phone functions only - Phone dependent
Voice Recognition Languages: Tuner/Media/Navigation - Phone dependent
Text-to-Speech (TTS) Languages - Phone dependent
Rider/Passenger Intercom - Headset function only
Vehicle Information Screen (Air temperature, oil pressure and EITMS) - Engine temp, Battery Voltage
USB - Charging and Instrument update, USB-C, 5V, 3A
Bluetooth - Yes
Pricing
Vivid Black - $17,319
Color - $17,569
ABS Option - Standard Cornering ABS
Security Option - Standard
Cruise Control Option - Standard
California Emissions - $200
Freight - $390
« Last Edit: February 22, 2021, 04:55:44 PM by adminjoe »
