Author Topic: valve adjustment  (Read 1089 times)
m-323
valve adjustment
« on: September 04, 2015, 02:21:50 PM »
hi, Im trying to set the valves on RCVF Honda XR200R. Motor is TDC, all valves are tight EXCEPT left intake. I fear the valve it stuck in the open position. How is this remedied?
Re: valve adjustment
« Reply #1 on: September 04, 2015, 03:08:26 PM »
Its real important to follow the steps in a repair manual for your motorcycle when doing routine maintenance or repair.
Valve adjustment is checked when the engine is at TDC on the compression stroke.
A bent valve requires pulling the head off and going from there......Determining why the problem occurred. Checking all related components for wear or damage, etc.
