Primer Bulb On A Stihl FS-110 Trimmer, Idle Problem
  • May 17, 2017
  • Comments Off on Primer Bulb On A Stihl FS-110 Trimmer, Idle Problem
Back of a Stihl FS-110
I came across a Stihl FS-110 trimmer that would run, but wouldn’t idle. At first glance everything looked as it should, but once my finger touched the carburetor primer bulb I could tell something wasn’t right. Rough edges had developed on the outer surface of the primer bulb created from cracks and breaks in the plastic, which will naturally occur in plastics over time. As soon as my finger applied pressure to the primer bulb it collapsed underneath my finger, and the problem with the trimmer not idling was found. It just goes to show how important a visual inspection is in the repair process.
Cracks and breaks in a Stihl FS-110 carburetor primer bulb
Front of a Stihl FS-110 trimmer engine
