Using A Scissor Jack With A Motorcycle Lift For Motorcycle Maintenance And Repair
  • March 1, 2016
  • Comments Off on Using A Scissor Jack With A Motorcycle Lift For Motorcycle Maintenance And Repair
Torin Black Jack 1.5 Ton Scissor Jack
If you use a full length motorcycle lift for motorcycle repair or maintenance, than you need a way to lift the rear wheel off the lift. Some high end motorcycle lifts provide a way to raise the rear wheel, but lower expensive lifts do not. A good solution is to use a scissor jack. Some of the benefits of using a scissor jack are:
  • Light Weight. Scissor jacks are extremely light weight when compared to other types of jacks making them easy to maneuver.
  • Reliable. Most scissor jacks are entirely mechanical and don’t contain any hydraulics. This makes them very reliable.
  • Low Profile. Scissor jacks collapse to a very low height allowing them to be used on motorcycles with the low ground clearance.
  • Low Cost. Scissor jacks are low cost and are carried at most auto parts stores, Target and Walmart.
  • Fast. Using a scissor jack is much faster than using a bottle jack.
  • Easy to store. Scissor jacks collapse to a low height making them easy to store underneath cabinets or tool boxes.
Motorcycle Lift With Scissor Jack
Scissor Jack Lifting Rear Wheel For Routine Maintenance
Torin Black Jack 1.5 Ton Scissor Jack Adjusting End
Torin Black Jack 1.5 Ton Scissor Jack End
Torin Black Jack 1.5 Ton Scissor Jack Instruction Label
Torin Black Jack 1.5 Ton Scissor Jack Label
Torin Black Jack 1.5 Ton Scissor Jack Right Side View
Torin Black Jack 1.5 Ton Scissor Jack Side View
Torin Black Jack 1.5 Ton Scissor Jack Underside
Categories: Motorcycle Repair
